thorburn 123 Report post Posted May 30, 2011 (edited) H&R sport e36 m3 springs. All still in very good condition. Part numbers: 29910 HA rear and 29910 VA front examples of height $300 Eibach springs for 6 cylinder e36. From the eibach bilstein kit. Shocks are stuffed. Should get you the ride height of simon328i's click me Part number: Z 056 A00 rear and Z 108 A00 front Actual picture below Teal coloured springs. Guessing they are dobi 6 cylinder springs. Just the front springs $100 Picture below Milltek cat delete for e46 330 Part number:MSBM113 - 31232 $500 Bottom to top: H&R's, Eibachs and Teal springs Edited May 30, 2011 by bbs Quote Share this post Link to post Share on other sites
nastnas 9 Report post Posted May 30, 2011 are you sure that is for an E36 M3? only asking as a google search, shows that part number for an E46. cheers, Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted May 30, 2011 I'm not sure actually. Cheers for pointing that out. I'll do a bit of a research on it now Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted May 30, 2011 Sorry for the mix up nastnas was right. Milltek cat delete is for an e46 330 Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted May 30, 2011 (edited) cat back might be good for my 30 james. if you dont sell come see me so i can have a play with it. Edited May 30, 2011 by kerry Quote Share this post Link to post Share on other sites
nastnas 9 Report post Posted May 31, 2011 bugger, was hoping this would fit my M3.... Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted May 31, 2011 The centre section is the same layout as the dual pipe e36's. But the pipe outside diameter is 54mm. Kerry do you mean the rear muffler or the centre section? Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted May 31, 2011 center section , you didnt list the rear. Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted June 7, 2011 bump. Might as well say eveything is ono as i'd like to make some space Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted June 11, 2011 eibachs $250 for bimmersporters untill someone has bid H&R's Milltek exhaust Teal springs $70 for bimmersporters untill someone has bid Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted June 18, 2011 Auctions finish today bump Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted July 4, 2011 eibachs $200 H&R's $250 Teal springs $50 Quote Share this post Link to post Share on other sites
