scott_e30 8 Report post Posted June 6, 2011 Im wanting to hook up my amp to my existing stock headdeck in an e46. My amp has an external bass control on it. Im not sure weather or not the head deck has output or inputs? Any help would be appreciated Cheers Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted June 6, 2011 you will need a amp with speaker level inputs , or get a speaker level input to rca adaptor . then hook up to the rear speaker cables etc Quote Share this post Link to post Share on other sites
rogan 17 Report post Posted June 7, 2011 http://www.bavariansoundwerks.com/category...0/bmw+subwoofer Go to the appropriate e46 page (coupe / sedan year etc). Click the install info tab down the bottom and you'll get step by step instructions with photos of what you need to do. Quote Share this post Link to post Share on other sites
btccm3 1 Report post Posted June 12, 2011 (edited) iv done it many times at work its very easy. you buy a high level input"speakers" to RCA adapter then simply T into the wires of two speakers behind the factory H/U. Then from the adapter run your RCAs and use the 12volt accessory wire at the H/U as your remote wire for the amp. easy... or you could just buy a fusion pre amped sub inclosure or tube sub as they already have high level inputs on the amp attached if you want to buy one of those adapters we sell them at my work not sure on price but we do have them in stock always. Hyper Drive on great south rd penrose Edited June 12, 2011 by btccm3 Quote Share this post Link to post Share on other sites
