Jimbothepunk 0 Report post Posted June 13, 2011 looking at boosting a m70 or 73 i wanna put some fordged pistons in there at least but i dont wanna do a full rebuild if the car is of fairly good condition low milage etc do you think i could get away withn just puttin the piston in? lucas Quote Share this post Link to post Share on other sites
thorburn 121 Report post Posted June 13, 2011 All depends on the condition of the engine. Pistons, rings and a hone might be all you need. While it's apart i'm sure you'll find if you need anything else. Plus you'll want to change the headgaskets, studs, and the usual bits. Not sure if these blocks are anything like the alloy 6 cylinder blocks strength wise. If they are you should probably helicoil the block Quote Share this post Link to post Share on other sites
Jimbothepunk 0 Report post Posted June 13, 2011 sweet thnaks thats what i was thinking Quote Share this post Link to post Share on other sites
