Eddie 66 Report post Posted July 3, 2013 Maintenance time already ?? Freebies !!! Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted July 13, 2013 (edited) we have added some side skirts and painted the rear bumper Edited July 13, 2013 by rot62 Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted July 13, 2013 To help Daniel learn when to change gears, I made a budget shift light A test with it set at 2000 rpm Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted July 13, 2013 At Pukekoke Quote Share this post Link to post Share on other sites
e30guydownunder 2 Report post Posted October 16, 2013 Awesome Project! Are you still running the XYZ coilovers? I have my own compact build in the works and gravel is the plan so I am interested to hear how you found them on the loose stuff Keep the updates coming! Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted May 24, 2014 Awesome Project! Are you still running the XYZ coilovers? I have my own compact build in the works and gravel is the plan so I am interested to hear how you found them on the loose stuff Keep the updates coming! The springs are to hard for Gravel but we are only there for fun. Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted May 24, 2014 (edited) Its been a while since Ive posted here some time to do an update. The car has been running flawlessly over the last year with the only draw back being the willwood brakes. They work very well but eat the rotors up . I have to replace the rotors each time we replace the pads. Edited May 25, 2014 by rot62 Quote Share this post Link to post Share on other sites
westy 614 Report post Posted May 25, 2014 Good good, keep us updated. Always keen to hear how others go about this sortta thing. Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted May 25, 2014 Swapping the engine out for a M54 here http://bimmersport.co.nz/topic/49423-e36-m54-engine-swap/ Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted June 15, 2014 The finished m54 install Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted June 15, 2014 (edited) Since that new engine got install I noticed the rear end walks around a little so I decided to replace the trailing arm bushes. I made up a dyi puller so I could remove the bushes without removing the arms from car. It worked good, less than hour to replace both rear arm bushes Homemade bush puller ready to go Success the bush is removed Edited June 15, 2014 by rot62 Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted June 26, 2014 painted the wheels black Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted June 26, 2014 First time I've seen a holesaw used as a bush tool. Ace! Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted June 30, 2014 Daniel managed to break an axle on the weekend 2 Quote Share this post Link to post Share on other sites
Beeker2 70 Report post Posted June 30, 2014 Daniel managed to break an axle on the weekend m3 rear end required ? Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted July 1, 2014 m3 rear end required ? That would be nice , But I can change a lot of axles for the cost of a M3 rear end Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted July 1, 2014 (edited) https://www.youtube.com/watch?v=G3gpXNiPy_A#action=share before the axle broke Edited July 1, 2014 by rot62 Quote Share this post Link to post Share on other sites
sonic_attack 89 Report post Posted July 1, 2014 Nice read this whole thread. Lucky kid, great dad! Quote Share this post Link to post Share on other sites
