Goonrider 0 Report post Posted July 4, 2011 Hello have a 2001 X5 and need a NZ map disk. Does anyone know where and how much these are. Quote Share this post Link to post Share on other sites
matt45 1 Report post Posted July 4, 2011 UK import so should have the euro nav (what you want), from bmw the maps are about $800 but there are probably copys floating around. may or maynot need coding to get it to work here .... someone else will be able to answer that. Quote Share this post Link to post Share on other sites
Goonrider 0 Report post Posted July 4, 2011 Thanks for your help again Matt. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted July 4, 2011 PMed Quote Share this post Link to post Share on other sites
NZLSAF 0 Report post Posted November 16, 2011 digging up an old post, but i just purchased a 99 e39 and was wondering if i could get the nav discs or the nav to work? it has the nav dvd unit at the top rear of the boot, but no disc Quote Share this post Link to post Share on other sites
kwhelan 242 Report post Posted November 16, 2011 digging up an old post, but i just purchased a 99 e39 and was wondering if i could get the nav discs or the nav to work? it has the nav dvd unit at the top rear of the boot, but no disc If its a nz new model yes just need a disk,jap import no the unit has to be changed Quote Share this post Link to post Share on other sites
kiwiland 3 Report post Posted November 16, 2011 If the Satnav computer is mounted in the top centre of the boot under the centre brake light then its a jap import and will not work in NZ Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted November 17, 2011 If the Satnav computer is mounted in the top centre of the boot under the centre brake light then its a jap import and will not work in NZ ...unless someone has already converted it and replaced the Jap DVD nav unit with a Euro Mk4 DVD nav unit. If it has the Mk4, insert the NZ map disc and it works. Quote Share this post Link to post Share on other sites
