gunter 0 Report post Posted July 20, 2011 Hi there, So my 325i started cutting out a while back and I bought a bosch 173 which from many different forum searches said cured the problem and it did for a while but now its back. I'm not saying its the computer because the 173 seems to have fixed everybody else's problems Any ideas? Cheers Tim Quote Share this post Link to post Share on other sites
BM WORLD 1297 Report post Posted July 20, 2011 all these things can be intermotant fuel pump dying?? faulty ecu relay?? faulty fuel pump relay?? crank sensor?? alarm wiring?? need to find out when it dies , does it still have spark??? then start looking at fuel stuff . if no spark then the electric side , lie crank sensor and relays and power supply to the ecu etc Quote Share this post Link to post Share on other sites
gunter 0 Report post Posted July 21, 2011 all these things can be intermotant fuel pump dying?? faulty ecu relay?? faulty fuel pump relay?? crank sensor?? alarm wiring?? need to find out when it dies , does it still have spark??? then start looking at fuel stuff . if no spark then the electric side , lie crank sensor and relays and power supply to the ecu etc Sweet that sounds good. Like you said its intermittent and doesn't usually last long enough to kill the motor but it has a couple of times. I think but I'm not sure that its a fuel issue but I'll keep watching and if I discover what it is I'll post back Quote Share this post Link to post Share on other sites
