pureboiracer 0 Report post Posted July 28, 2011 Hey guys, My e34 540 has developed a loud rattle/knock. It sounds like something is rattling rather loudly underneath the center console around the handbrake area, i removed the center console and it is still there, ive determined that its coming from under the car in the trans tunnel area, it sounds like a metal bracket is hitting the tunnel under certain acceleration points. The knock occurs when accelerating, up hills, from a stop etc. its not usually there when at constant speed on a flat. My first thoughts here are a worn hanger bearing causing the driveshaft or the hanger to slap about. The car goes on a hoist on wed so i will check out the driveshaft then, i was just wondering if there was anything else around that area that could or has been known to cause a similar sound? Cheers Oli Quote Share this post Link to post Share on other sites
topcat 11 Report post Posted July 28, 2011 Hey guys, My e34 540 has developed a loud rattle/knock. It sounds like something is rattling rather loudly underneath the center console around the handbrake area, i removed the center console and it is still there, ive determined that its coming from under the car in the trans tunnel area, it sounds like a metal bracket is hitting the tunnel under certain acceleration points. The knock occurs when accelerating, up hills, from a stop etc. its not usually there when at constant speed on a flat. My first thoughts here are a worn hanger bearing causing the driveshaft or the hanger to slap about. The car goes on a hoist on wed so i will check out the driveshaft then, i was just wondering if there was anything else around that area that could or has been known to cause a similar sound? Cheers Oli sounds like a hanger-bearing.diffenatly check your driveshaft. Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted July 28, 2011 also if the hanger is gone the rubber driveshaft coupling (donut) will most likly be stuffed as well . can help with parts if you need. 021433600 thanks brent Quote Share this post Link to post Share on other sites
