master garion 1 Report post Posted July 30, 2011 Hey guys I've just bought some butyl sealant from the dealer with the intention of resealing the moisture barrier on a rear door. I have water leaking into the footwell. The barrier is in terrible state and torn in many places. Other than buying a new one from the dealer (unsure of price), is there a good alternative, say like plastic sheeting cut to size? Has anyone done this before? Also, any ideas on how to remove the old sealant from the door? cheers Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 30, 2011 I would suggest you use the correct part. If you saw what was under the floor you would appreciate why, long term Quote Share this post Link to post Share on other sites
master garion 1 Report post Posted July 30, 2011 I would suggest you use the correct part. If you saw what was under the floor you would appreciate why, long term Glenn, do you mean the sound insulation aspect of the barrier? If so, I would definitely go with the BMW part. Cheers. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 30, 2011 Glenn, do you mean the sound insulation aspect of the barrier? If so, I would definitely go with the BMW part. Cheers. Its not really sound insulation as such, it's more of a weather seal to stop water that gets into the doors getting into your car. Quote Share this post Link to post Share on other sites
master garion 1 Report post Posted July 30, 2011 I've got this part on order now. Glenn, how do I remove the old butyl? Quote Share this post Link to post Share on other sites
