Jedan71 0 Report post Posted August 2, 2011 E36 318i Auto M43 Engine: A problem that is causing me massive headache, also going to hit the wallet big time, I desperately need help! The car stutters whilst driving @ 1700 - 2500 rpm and can stall when the revs drop at stopping. The problem doesnt really occur when fuel is greater than appx 1/2 tank or greater. Only occurs when warm. Diagnostic machine at garage shows no faults. Recent water pump change. CCV/PSV valve changed. Inlet manifold all cleaned. Changed fuel pump as though fuel related but fault came back 2-3 days after change. When driving @ steady 2k -> 2.5k revs, on the fuel comsumption gauge pulses and driving up hill the car feels like it is pulsing. Please Help me! Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted August 2, 2011 faulty air flow meter?? have the spark plug leads been checked??(oil in the holes ,cracks in the rubber etc) also check for water in the ecu box etc. is it parked on a hill?? left side down?? massive vac leak?? Quote Share this post Link to post Share on other sites
Jedan71 0 Report post Posted August 2, 2011 faulty air flow meter?? have the spark plug leads been checked??(oil in the holes ,cracks in the rubber etc) also check for water in the ecu box etc. is it parked on a hill?? left side down?? massive vac leak?? I am unable to find any leaks? i believe i dont have a air flow meter , it is a other version, have attached a photo of my version. i thought air leak would give me constant issue though, stored on driveway at night with ever slight incline, front end down Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted August 2, 2011 (edited) I am unable to find any leaks? i believe i dont have a air flow meter , it is a other version, have attached a photo of my version. i thought air leak would give me constant issue though, stored on driveway at night with ever slight incline, front end down thats a afm , just the old barn door flap type (just after the air filter box)they do fail and wear out , i sell a few. also have you pulled out and inspected all the HT spark leads , sell a few of these as well Edited August 2, 2011 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
