98_s14 0 Report post Posted August 23, 2011 Hi all, I'm looking for a prefacelift E30 idle up valve for a 320i, this is the bit under the intake manifold which has two water hoses and two air hoses going into it. Its like a little thermostat the idles the engine up when cold. I'm sure someone knows what I mean, Cheers Michael Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted August 23, 2011 Are you sure it's the valve and not just a blocked coolant hose or fitting that goes to the valve?? Quote Share this post Link to post Share on other sites
98_s14 0 Report post Posted August 28, 2011 Are you sure it's the valve and not just a blocked coolant hose or fitting that goes to the valve?? Hi Glenn, yes I'm sure. It was all 100% clean before being put together and the coolant lines are getting warm. I still need one if someone has one, cheers Quote Share this post Link to post Share on other sites
98_s14 0 Report post Posted September 9, 2011 Bump. The used one I got the other day doesn't close properly either, even with a good dousing in CRC. Someone must have one of these lieing around, Cheers Michael Quote Share this post Link to post Share on other sites
