cytamen 1 Report post Posted August 26, 2011 Hey, Got a few leftovers from my recent transmission conversion. I have shifter linkages from a Getrag 225 along with a clutch and flywheel used on my e36 323i There should also be a working starter motor in the box. All parts were working, but clutch had a slip at high RPM as it wasn't the right clutch for my car. Might be fine on an engine with less power. Located in Birkenhead Also have some Euro plate surrounds which I no longer need.. $10 Quote Share this post Link to post Share on other sites
cytamen 1 Report post Posted August 28, 2011 Hey, Got a few leftovers from my recent transmission conversion. I have shifter linkages from a Getrag 225 along with a clutch and flywheel used on my e36 323i There should also be a working starter motor in the box. All parts were working, but clutch had a slip at high RPM as it wasn't the right clutch for my car. Might be fine on an engine with less power. Located in Birkenhead Also have some Euro plate surrounds which I no longer need.. $10 Nobody want them? I'll throw in the euro plate surrounds free if you just take it away! Cant be bothered throwing away usable parts at the rubbish dump Quote Share this post Link to post Share on other sites
Scorched_onion 0 Report post Posted August 28, 2011 (edited) Nobody want them? I'll throw in the euro plate surrounds free if you just take it away! Cant be bothered throwing away usable parts at the rubbish dump Ill take the clutch, flywheel and starter if i pay postage to hamilton? Is it from an e36 323? Edited August 29, 2011 by Gapin_it Quote Share this post Link to post Share on other sites
