dubman
Correct method to check coolant?
Just replaced my water pump, then i bled the system etc and let all the air out using the bleed valve. heated up car and let it cool down 3 times and made sure it was filled correctly
This morning, i checked my coolant level again. It was low, but then i unscrewed my bleed valve, followed by my radiator cap. Then the coolant rose to the correct "cold mark".
Question: is this the correct way of checking coolant level when cold for a m40? Thanks
Edited by dubman
