my_e36
TC, SC, ASC+T, ABS, confused...
As far as I understand....
Traction Control (TC) = Stop the wheel spinning when accerlerate
Anti-lock Break System (ABS) = Stop the wheel locking when breaking
Stability Control (SC) = Able to apply 1 front break to counter oversteer or 1 rear break to counter understeer
now... E36 has ASC+T, but is it that we got in E36 are all the 3 above combined??
What does the "A" makes the ASC different from other SC in other brands?
A is for Active
B is for Banana
C is for Cookie
ASC+T is Automatic Stability Control + Traction. It applies the brakes and retards your engine as required to stop you spinning up or out.
ABS, is only works when you are braking and is a separate item in your car.
Depends on what version you have on how it works exactly.
isnt the abs system(or part of it) the part that actually allows the brake to be applied automatically???...sorry cant actually explain or ask what i want to ask :(
Guest Andrew
no -
ABS is simply anti-lock braking system.
Active Stability Control + Traction Control will alter throttle and brakes.
Dynamic Stablity Control is way more advanced - will alter throttle if if you do too much steering lock, brake individual wheels, change damper settings on the fly etc launch the space shuttle..
oh i thought the accumulators or whatever supplied the epressure to allow the brakes to be aplied at any time....my bad
