Coffee&Doughnut 0 Report post Posted May 25, 2005 Does anybody know if a LSD from a 323i E21 late model early 80s will work in a 320i E30? Quote Share this post Link to post Share on other sites
nath 176 Report post Posted May 25, 2005 did they have lsd's? well if you have the whole 323i still, keep it in! it should fit in though i think Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted May 25, 2005 Does anybody know if a LSD from a 323i E21 late model early 80s will work in a 320i E30? It will - would be easier to transfer all the diff internals to a e30 case diff. I think the subframe mounting points are different. Quote Share this post Link to post Share on other sites
Coffee&Doughnut 0 Report post Posted May 25, 2005 The 323i is a wreck and the guy at the yard said he was pretty sure it had a LSD in it, I was thinking maybe I could salvage it, I dont know what ratio it is, but then again what about the manual gear box would that bolt up as well? I could probally just take the whole thing off his hands would be easier but I dont know if I have the space. Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted May 25, 2005 According to the all powerful ETK: The LSD Centre was only used on E21's, How ever the side bearings are the same as a type 168 (small case) diff (found in E30/36's). The stub axles are also E21 specific, whether that is because the splines count or dia. is different!?!?! And No the complete diff will not bolt into a E30 subframe. If you can get it cheap enough, have a play!! Oh, BTW it should be a 3.45:1 Quote Share this post Link to post Share on other sites
