Coffee&Doughnut
E21 LSD
did they have lsd's? well if you have the whole 323i still, keep it in! it should fit in though i think
Guest Andrew
Does anybody know if a LSD from a 323i E21 late model early 80s will work in a 320i E30?
It will - would be easier to transfer all the diff internals to a e30 case diff.
I think the subframe mounting points are different.
The 323i is a wreck and the guy at the yard said he was pretty sure it had a LSD in it,
I was thinking maybe I could salvage it, I dont know what ratio it is, but then again what about the manual gear box would that bolt up as well?
I could probally just take the whole thing off his hands would be easier but I dont know if I have the space.
According to the all powerful ETK:
The LSD Centre was only used on E21's, How ever the side bearings are the same as a type 168 (small case) diff (found in E30/36's).
The stub axles are also E21 specific, whether that is because the splines count or dia. is different!?!?!
And No the complete diff will not bolt into a E30 subframe.
If you can get it cheap enough, have a play!!
Oh, BTW it should be a 3.45:1
