deshanv 0 Report post Posted September 20, 2011 Hi guys, trying to make a decision on a 10 inch sub for my bmw. Choices are: 1. Kicker SOLO-BARIC L7 - 10 inch 2. Soundstream T5 10 The amp I have choosen is the Kicker 1 channel DX 1000.1 Monoblock. I have really good reviews on both though, but my gut is to go for the kicker L7. Quote Share this post Link to post Share on other sites
KRZY-E30 0 Report post Posted September 20, 2011 I'd Choose Kicker IMO. Quote Share this post Link to post Share on other sites
E36 M 9 Report post Posted September 20, 2011 (edited) Its a no brainer, Soundstream. I Had a kicker 15 in my wagon previous, wasn't what i wanted, was about to buy another 15 kicker to get what i wanted, but then bought a T5 15 Soundstream and i would not buy anything else, perfect for what i needed. EDIT: Realised you wanted a 10" so yeah probably kicker. Edited September 20, 2011 by Jedi Mind Tricks Quote Share this post Link to post Share on other sites
rogan 18 Report post Posted September 20, 2011 (edited) What are you wanting out of the sub? Basically you asked whether to buy a Ford or a Holden: without knowing if you want SQ over SPL or viceversa then it's an impossible question to answer. Both are loud, the Kicker would probably go louder but the SS will probably sound better. Also depends on enclosure - ported vs sealed and what space you have to play with. Edited September 20, 2011 by rogan Quote Share this post Link to post Share on other sites
deshanv 0 Report post Posted September 21, 2011 What are you wanting out of the sub? Basically you asked whether to buy a Ford or a Holden: without knowing if you want SQ over SPL or viceversa then it's an impossible question to answer. Both are loud, the Kicker would probably go louder but the SS will probably sound better. Also depends on enclosure - ported vs sealed and what space you have to play with. Hi Mate, I am looking for sound quality with precision thump. I have a convertible, so not much boot space, thus going for a 10 inch sub Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted September 21, 2011 why 10inch also? 12 will give more bang and similar response. Quote Share this post Link to post Share on other sites
deshanv 0 Report post Posted September 21, 2011 why 10inch also? 12 will give more bang and similar response.Because I don't have enough space in my boot for a 12 inch. Quote Share this post Link to post Share on other sites
M5V8 337 Report post Posted September 21, 2011 Hi Mate, I am looking for sound quality with precision thump. I have a convertible, so not much boot space, thus going for a 10 inch subsounds like you should go soundstream with a custom sealed enclosure. Quote Share this post Link to post Share on other sites
rogan 18 Report post Posted September 27, 2011 Another option could be the DLS Nobellium 10 that's for sale on nzicemag forums. $300 BNIB from a guy who cares about his gear. It wants a small ported box if I remember correctly. Would expect it to out perform the SS and the Kicker on sound quality but not sure exactly how much power it can handle. Quote Share this post Link to post Share on other sites
Neal 576 Report post Posted September 27, 2011 If you can find one still go for a boston c110 sub. These are a high powered sub in a very small box as a result of running a 10 inch bass and a 10 inch passive radiator and i suspect they'd fit under the roof housing in your boot.They can take a ton of power and produce fast and tight bass. They are a two ohm load so will load up the power nicely on most single channel bass amps. They sound best with lots of clean power ( I'm running a 600rms class D soundstream amp for bass duties) A car stereo dealer was amazed at how well in performed compared to the current crop of mid range subs and I'm yet to find a replacement which produced quality bass from such a small enclosuer. Otherwise BSW make a good sub that uses the ski port into fire bass into the car for a conv. http://www.epinions.com/specs/pr-Boston_Ac...0_Car_Subwoofer Quote Share this post Link to post Share on other sites
deshanv 0 Report post Posted September 29, 2011 If you can find one still go for a boston c110 sub. These are a high powered sub in a very small box as a result of running a 10 inch bass and a 10 inch passive radiator and i suspect they'd fit under the roof housing in your boot.They can take a ton of power and produce fast and tight bass. They are a two ohm load so will load up the power nicely on most single channel bass amps. They sound best with lots of clean power ( I'm running a 600rms class D soundstream amp for bass duties) A car stereo dealer was amazed at how well in performed compared to the current crop of mid range subs and I'm yet to find a replacement which produced quality bass from such a small enclosuer. Otherwise BSW make a good sub that uses the ski port into fire bass into the car for a conv. http://www.epinions.com/specs/pr-Boston_Ac...0_Car_Subwoofer Thanks, can you post a picture of your setup please. Quote Share this post Link to post Share on other sites
