drifty325i
20mm spacers?
Hey does anyone know where you can get spacers for e30s?
i have momo gt2s on my car running 17in 205s all round but there
is a big ugly gap of about 20mm between the tire and guard i already
have crappy
spacers on at the mo but only bout 5mm thick.i would kike to put 215 on the back if i can find some to suit. any help would be awesome thanks
There are a few around, prolly cheapest to get them ex. USA.
Rouge engineering
H&R
Turner Motorsports
Or get some made loacally, Les Hunter (chch) could prolly whip some up for you.
You will also be needing a cert plate to run them, and they are not "Spacers" they are adaptors as far as LVVTA are concerned.
What you are currently using are illegal, as are your wheels if they are not hub-centric.
what otheroptions are there to space my mags out ? needs to look fatter
Spacers a.k.a adaptors, are dangerous!
Spacers are dangerous and illegal!!
Properly made adaptors are perfectly safe and legal with a cert plate!!
But of course nothing is always best!!
Znoelli in auckland do them hub centric and bolt on, perfectly safe and certifiable, but not cheap $125 each I think for 25mm, the only risk is under extreme conditions you have two sets of threads holding each wheel on instead of one = twice the risk of something failing
thanks guys for the help.
