Dr. M
E36 driveshaft question
Anyone see a problem with shortening the front half of an M43 manual driveshaft to suit an m50 (-32mm). Center bearings, threaded ring etc all same P/Ns, rear sections same length afaik.
Cheers
Edited by NZ_BMW
Is it not possible to take up the 32mm where the two half join, spline area of the drive shaft.
Not sure; is there enough length in spline area? Haven't received parts yet so haven't had a play etc. Great if there was, I'd save $250 ;)
