Specter13
E30 regulator motor woes
both R/H windows dont go up or down so i decided to fix the problem.
narrowed the problem down to the regulator motors. took them off the regulator, and look fine. spin quite happily off the regulator. if i put them back on flush with the plastic casing doesnt work :o
if i adjust the screws so there is about a 4mm gap. the motor will wind down the window happily, on the way up it stutters/crunches, the works. the regulator is fine and travels freely.
on a side note i realised my passenger window runs of a screw regulator system? the drivers door uses a regular roller arm setup.
any ideas?
