DrphTa
How to remove tints
Removed all but one of my window tints a few weeks ago.
Im having trouble getting the rear window one off without F@#$% the demister. I took a sheet off the rear window but there is two layers of tint. The first one simply pulled off, the second im having trouble with as it wont just pull up.
Any ideas?
You could go see the guys @ Mastertint Southport I'm sure they will remove it for free or a small charge.
Southport is pretty close to me, thanks mate
If that doesn't work out - have someone heatgun the outside while you pull it from the inside. You'll probably end up with sh*t all over the back windows so you'll need some degreaser too + heaps of window cleaner.
i was going to attempt mine but to save you trouble/time , i just rung tint guys cost me 50 bucks and took 15 minutes on the wagon
Prepsol, easy as after you wipe it on
