mossline
E39 headlight problem
Hi guys, so a while back on a trip up the country i noticed one of my high beams were on, I pulled over, took the key out of the ignition and the light was still on. For a temp fix I just disconnected the bulb.
But now WOF time is nearing.....
I know its the LCM thats spazzed out but I was hoping to avoid touching the LCM and going down another route but would like your guys' advice on whether what i want to do will work ok or not?
I figured I could just run a wire from the headlight that DOES work properly so that when it is activated, the offending side comes on too thus bypassing the LCM.
Will this work ok?
Thoughts/ ideas?
Thanks in advance.....
Will this work ok?
Thoughts/ ideas?
This is likely to overload the LCM and throw a fault code on your display
Thats what I figured but to be honest a fault code isnt really going to bother me as long as it works and doesnt mess up the actual workings of the LCM.
Where would I send the LCM if I wanted to get it repaired and roughyl how much do you think I would be looking at?
Thanks Glenn!
Thanks Glenn!
Give me a call
