android
cam cover leak
http://www.bimmersport.co.nz/forums/style_...icons/icon1.gif hi i have a e36 2.8 1995, and have noticed it has a tiny oil leak, i have finally tracked it down to a small cam cover . can anybody tell me if i can pop off the circlip and change the o ring with out having to strip out the whole area , any advice would be great . cheers A
Not sure what you are talking about. The cam cover is held down with 15 bolts and 15 bolt seals. Can you describe it better or post up a picture
