Archie 0 Report post Posted December 12, 2011 Hi guys, lurker here with a problem. When I leave my 87 325 for ~1 week, it becomes near impossible to start. The battery drains, but even charged up you can crank it all you like with no results. It does eventually start after a 2km tow, but that is far from ideal. When it does start, it runs very badly for a while. It won't hold idle, dies on reasonably hard acceleration (nowhere near WOT), and misses above 4.5k revs. There is also a bit of smoke I don't usually see. However, after a brief run (drive about 10kms), it's all fine again. No missing, idles well, starts first crank. Any suggestions? Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted December 12, 2011 Sounds like it could be a battery/alternator issue, have you had the battery checked? Quote Share this post Link to post Share on other sites
Archie 0 Report post Posted December 12, 2011 Haven't had it tested, but even with it hooked up to a running diesel 4x4 for 1/2 an hour it still didn't start with the crank. Surely it's not a battery issue then? Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted December 12, 2011 what colour smoke?? black smoke is fuel , white smoke is oil could be valve guides worn allowing oil to drain into the cylinders and fowling the spark plugs. black smoke , could be cold start injector (or normal injectors) leaking excessive fuel into the intake system and wetting the plugs. Quote Share this post Link to post Share on other sites
Archie 0 Report post Posted December 13, 2011 Yep it was definitely black/blue smoke. How can I test to see which is leaking? I find it weird that it is running perfectly now. I've also been reading about the fuel pump check valve not working, which seems to create a similar problem with an empty fuel rail, but not as bad. Cheers for the help Quote Share this post Link to post Share on other sites
Archie 0 Report post Posted December 24, 2011 A friend has suggested this could be the ECU forgetting settings when the battery goes flat. Is this plausible? Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted December 24, 2011 A friend has suggested this could be the ECU forgetting settings when the battery goes flat. Is this plausible?NO Quote Share this post Link to post Share on other sites
Archie 0 Report post Posted January 6, 2012 To add to the mystery, I left it again for a week with the battery unplugged. On returning, it started straight away, this time with some white smoke. I tried to drive it but it wouldn't rev beyond ~3.5k rpm. It would pull cleanly to that point, then stop spark apparently, spluttering and backfiring badly. I left it for a night, and the next day it was nearly perfect. No smoke on starting. Early in the day (I drove 6 hours), it would splutter on deceleration sometimes, but this cleared up within an hour. No oil or water appears to have been used. I am going to put new spark plugs in to remove that from the equation. Quote Share this post Link to post Share on other sites
