Jono51 61 Report post Posted December 14, 2011 (edited) Decided to focus on another project soon so the following is surplus to my requirements and could be of use to someone here to replicate a 325is or upgrade your E30 Front.... front E36 hubs 328i brake calipers Rotors E36 struts E36 M3 lower arms M3 EVO new Delrin offset control arm bushes front jamex springs (you will need camber plates and can help sourcing them for extra) rear end rear subframe with delrin bushes fitted Ti arms, with new bushes rotors calipers comes with a set of bbs weaves 5 stud $1250 can freight nationwide on a pallet for additional cheers Jon 04 3801089 Edited December 15, 2011 by JKSE Quote Share this post Link to post Share on other sites
nipe 1 Report post Posted December 14, 2011 Are the struts from e36 m3? or just e36? And the front hubs m3 too? Quote Share this post Link to post Share on other sites
Jono51 61 Report post Posted December 14, 2011 Are the struts from e36 m3? or just e36? And the front hubs m3 too? hubs are 328 , as with the struts cheers Quote Share this post Link to post Share on other sites
nipe 1 Report post Posted December 14, 2011 hubs are 328 , as with the struts cheers The struts will not work I'm pretty sure. Because the normal e36 uses larger diameter springs comparedto m3, which uses e30 diameter springs. And the normal e36 hub will keep the wheel off center. (Not trying to be a d*ck, just clarifying) Quote Share this post Link to post Share on other sites
Jono51 61 Report post Posted December 14, 2011 (edited) The struts will not work I'm pretty sure. Because the normal e36 uses larger diameter springs comparedto m3, which uses e30 diameter springs. And the normal e36 hub will keep the wheel off center. (Not trying to be a d*ck, just clarifying) Edited December 14, 2011 by JKSE Quote Share this post Link to post Share on other sites
Jono51 61 Report post Posted December 14, 2011 (edited) The struts will not work I'm pretty sure. Because the normal e36 uses larger diameter springs comparedto m3, which uses e30 diameter springs. And the normal e36 hub will keep the wheel off center. (Not trying to be a d*ck, just clarifying) no matter what you use will be off centre slightly, hence using Evo m3 arms , offset control arm bushes and camber/ castor plates to improve caster,this is the trade off that you get when going to 5 lug in this situation and many have done it. as for the spring they fit in the strut tower otherwise I wouldn't have bothered.I've offered it for sale, as i'm about to build another car, and thought it a shame to part it all out, as someone here may find some use for it, failing that I could always aborb all the parts into my fleet of vehicles over time cheers Edited December 15, 2011 by JKSE Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted December 14, 2011 For the wheels to centre properly you must use the M3 Evo arms, the normal M3 arms are different again. Quote Share this post Link to post Share on other sites
Jono51 61 Report post Posted December 15, 2011 (edited) For the wheels to centre properly you must use the M3 Evo arms, the normal M3 arms are different again. Gidday Dave I should have clarified they are in fact M3 Evo I'll edit th advert cheers Jon Edited December 15, 2011 by JKSE Quote Share this post Link to post Share on other sites
APT 205 Report post Posted December 15, 2011 For the wheels to centre properly you must use the M3 Evo arms, the normal M3 arms are different again. Yup thats what i used in my setup and worked a treat! Quote Share this post Link to post Share on other sites
