_ethrty-Andy_ 2153 Report post Posted December 15, 2011 I have some spacers that dont have hubcentric rings on the wheel side so im getting some cylinders made up that can be pressed into the spacers. They will effectively be 72.5mm cylinders and are pressed into your spacers half way, so you have a lip for your wheels to mount onto, while maintaining room to fit spacers over you hubs. Will not be welded as not necessary as pressure fitted, and are tapered to a very very small degree. All drawn up by qualified engineers etc etc not a home job. BMW sizes only (72.5mm), cant be bothered organising them for your nissan or whatever. You could then use nylon hubcentric adaptors if you have non-oem bmw wheels with a larger hub centerbore on the rim THIS IS A REQUIREMENT FOR YOUR SAFTEY AND ALSO FOR CERT/WOF If anyone else wants in let me know. You will need to send your spacers to me so they can press them in. Price for a set of 4 is between 160 and 180, and 100 for a pair. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted December 15, 2011 Oh and will need to know tonight so i cant let them know to make them up when i visit tomorow. Quote Share this post Link to post Share on other sites
