Top Secret 2 Report post Posted December 20, 2011 I acquired some, but I think it was out of a SA import and thus needs the thick separate underlay, which will be a pain to find. So, I need some grey carpet with the foam underlay, or if someone is wrecking an SA model with the separate sound deadening, I could be interested Cheers! Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted December 20, 2011 Might be able to help you out but I'll have to check. For a coupe or a 4 door?? Quote Share this post Link to post Share on other sites
nipe 1 Report post Posted December 20, 2011 I want one toooo:) Quote Share this post Link to post Share on other sites
Top Secret 2 Report post Posted December 20, 2011 Might be able to help you out but I'll have to check. For a coupe or a 4 door?? Coupe/4 door doesn't matter, it just needs to be the front section I'm pretty sure. Oh, I'm in Hamilton/Tauranga, but I'm sure we can come to some sort of an arrangement if you're elsewhere. Quote Share this post Link to post Share on other sites
Top Secret 2 Report post Posted January 3, 2012 Bump, someone must have a spare one! Also need a pair or set of e30 bottlecaps with tyres for cheap. Or basketweaves Quote Share this post Link to post Share on other sites
