curryinahurry 39 Report post Posted December 22, 2011 Hi guys, a friend of mine recently acquired an 04 730 but for some reason the angel eyes don't work. When you switch the light switch to the first position, a small halogen bulb comes on instead of the angel eyes - would anyone know why this is the case? Cheers, A Quote Share this post Link to post Share on other sites
tobytoblerone 3 Report post Posted December 22, 2011 Hi guys, a friend of mine recently acquired an 04 730 but for some reason the angel eyes don't work. When you switch the light switch to the first position, a small halogen bulb comes on instead of the angel eyes - would anyone know why this is the case? Cheers, A Some of the pre-facelift e65's didn't have angel eyes, instead use parklights similar to those on previous 7 series. Even though it appears the angel rings are there, they are actually not used... Wierd they would still put the rings there, is the car from japan or Singapore? Quote Share this post Link to post Share on other sites
curryinahurry 39 Report post Posted December 22, 2011 Some of the pre-facelift e65's didn't have angel eyes, instead use parklights similar to those on previous 7 series. Even though it appears the angel rings are there, they are actually not used... Wierd they would still put the rings there, is the car from japan or Singapore? Arr that must be the case. I wonder if theres any way to enable them? The car is from Singapore. Quote Share this post Link to post Share on other sites
tobytoblerone 3 Report post Posted January 3, 2012 Arr that must be the case. I wonder if theres any way to enable them? The car is from Singapore. Hmm if there is a location for the bulb for the angel eyes then it would work. (note the headlights require the bumper to be removed first to remove the headlights) If not, then you would need a set of new headlights which are very expensive! Want me to take a look at it for you? Quote Share this post Link to post Share on other sites
MaxHeadroom 0 Report post Posted February 4, 2012 Hmm if there is a location for the bulb for the angel eyes then it would work. (note the headlights require the bumper to be removed first to remove the headlights) If not, then you would need a set of new headlights which are very expensive! Want me to take a look at it for you? Hi, same here. Just got a Dec03 745Li and halogens and park bulbs, no way to put in an angle eye bulb, but the lights seem to have angle eyes in them. Wonder if you cut the blank circle out where the angle eye light should go, will the mounts etc be in the headlight as well? Wondering if anyone has butchered a set to find out in the past. Quote Share this post Link to post Share on other sites
cravin2012 0 Report post Posted February 7, 2013 Hi, same here. Just got a Dec03 745Li and halogens and park bulbs, no way to put in an angle eye bulb, but the lights seem to have angle eyes in them. Wonder if you cut the blank circle out where the angle eye light should go, will the mounts etc be in the headlight as well? Wondering if anyone has butchered a set to find out in the past. I have a 2003 745iL also, mine has angel eyes, I replaced the bulbs for LED setup... Was easy and improved the look of my car... Maybe your bulbs have blown... Quote Share this post Link to post Share on other sites
