shaneg 0 Report post Posted January 12, 2012 Does anyone have this in stock? p/n 11617501563 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 12, 2012 Buy a new one... these are prone for giving problems Quote Share this post Link to post Share on other sites
shaneg 0 Report post Posted January 13, 2012 Yes a new one.. not after a second hand item. Mine has failed yesterday.. Have found it online at oembimmerparts for $77.85usd but wanted to get it locally if possible. Have just driven 3285km since the 27th of Dec, so something was bound to pop up, car has been awesome the whole time however. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 13, 2012 (edited) If your going to do it yourself, try Euro Italian our sponsor, McMillans or BM Workshop in Grey Lynn for the parts. Also make sure you use good quality torx sockets otherwise you'll end up having to remove the plenum chamber. It's quite easy with the right tools, can turn to crap quite easy as well. Edited January 13, 2012 by *Glenn* Quote Share this post Link to post Share on other sites
shaneg 0 Report post Posted January 13, 2012 Cool, thanks. I've moved to queenstown otherwise id bring it in.. Have found a great tutorial about it that Edwin made on bimmerforums. Also any recommendations for a good specialist down here? Can't find any, although there is a merc and range rover specialist failing that. Don't mind heading through to Alex/Cromwell etc. Dunedin maybe. Still need to find that little oil leak.. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 13, 2012 Cool, thanks. I've moved to queenstown otherwise id bring it in.. Have found a great tutorial about it that Edwin made on bimmerforums. Also any recommendations for a good specialist down here? Can't find any, although there is a merc and range rover specialist failing that. Don't mind heading through to Alex/Cromwell etc. Dunedin maybe. Still need to find that little oil leak.. Don't know of anyone down that way.. I'm sure one of the mainlanders will chime in with a recommendation. It might mean travelling a fair way though. Quote Share this post Link to post Share on other sites
