byza213
wtb : 8mm/9mm slip on spacers 4x100
is it possible to get slip on spacers this size that are hubcenttic and non multi 4 stud type just in 4x100 size?
can they be threaded to the hub of wheel?
just in regards to getting a cert with coilovers
ideally id like more meat on tyres but are 195/45/16 certable ?
help help ! just want to clear up a few things first time going through this process , i understand there is info on the net just want to know from guys that have been through it
thanks
no slip ons, needs to be hubcentric and bolted to hub, then wheel to spacer
i have some 10mm slip ons with 57.1-> 73 hub center if you want to try them for testing
yea man keen to try on if thats ok
10mm might push wheel out guard more
whats the law with that ?
