yng_750
deals at supacheap
hey guys was in at my local SCA today and saw they have their digital current testers ( plugs into blade fuse hole and gives read out of amperage) and also their sound meters (40db to 130db with min and max and live readout)
both down from $50 odd to $15 each
apparently good but not big sellers so clearance to get them out
i bought one of each though you guys might be keen if so check em out before they are gone
Current testers are good.
yea i had a quick play today they read out XX.XX amps so you can track amperage when the ignition is off for drain tracing and see how much each item draws as you turn it on
Sound meter might come in handy for $15, is it ok for measuring exhaust noise?
yea i gave it a go
it doesnt accurately pick up really sudden snaps of sound like a bang but anything over half a second or so is good
max function is handy when working alone, as is the foam microphone cover to cut out wind noise
and it has a threaded hole in the back for mounting on a tripod
