rusteee 52 Report post Posted February 10, 2012 Hi there. Finally got the new car and loving it. Only issues I've found is the memory buttons for seat etc don't really work correctly. If I push button '3' the seat and wheel will move to a random position. Buttons '1' '2' and 'M' do nothing at all. I read through the manual on how to programme etc, but upon pushing the 'M' no light or anything comes on, and does not keep the settings. I've checked the plug on the side of the seat to ensure all in correctly etc, but no issues there. Does anyone know what may be causing this? Also the drivers window will not auto up. It will auto down OK, and all other windows are fine, but it will not auto up. Could this possibly be an issue with the pinch senor? If so does anyone know how to test it? Cheers in advance Quote Share this post Link to post Share on other sites
Allanw 1080 Report post Posted February 11, 2012 The pinch sensor affect manual as well - if you wind the window up, and push on the srround at the top, it will stop and go down a bit. You can program the auto up for each window, and which direction - You's may have been changed, but you might also have a dodgy button. The seat is a bit confusing, but I seem to recall that can be programed to work from each individual key. Not sure that you can program it to NOT work off the buttons though. Perhaps the M button is faulty, so the others can't be programmed? Quote Share this post Link to post Share on other sites
