byza213 1 Report post Posted February 22, 2012 as per title maybe even some e34 style 5 16x8 let me know thanks Byron Quote Share this post Link to post Share on other sites
byza213 1 Report post Posted February 22, 2012 would these work . http://www.trademe.co.nz/Browse/Listing.aspx?id=451059382 Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted February 22, 2012 They should be fine The only funny in your case would be E39 wheels - would require hub centric rings Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted February 22, 2012 e34play said: would these work . http://www.trademe.co.nz/Browse/Listing.aspx?id=451059382 yes they will work but you will need hub rings .also look out for the e38 version of the same wheel , they are 8" wide and et23 . so just be carfull with your tyre choice (width and rim protector size) otherwise they might rub on the inside of the front struts i use a set of these with my semi slicks 225 wide on my e28 . had them before as road wheels with bridgestone grid3 tyres 225/50-16 but they rubbed a bit on the inside , so just made small dent in the strut tube for clearance. Quote Share this post Link to post Share on other sites
byza213 1 Report post Posted February 22, 2012 thanks for that information Brent/ Simon where to get them hub rings? if anyone sees something dont be shy to post in here Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted February 22, 2012 e34play said: thanks for that information Brent/ Simon where to get them hub rings? if anyone sees something dont be shy to post in here mag and turbo sell them and i am sure there are plenty of other mag shops that have or get them Quote Share this post Link to post Share on other sites
Guest 4167 Report post Posted February 22, 2012 (edited) 16x7 is better fit to E28 and tyre must use 215 50 or 55 R16 not 225. and I dont know 16x 8 will fit.I fit 16x8 to my e39 and it become outer,I think will touch the inner guard if for E28. rings try Jono @ magswheels direct.I have been bought a set from JONO Edited February 22, 2012 by 4167 Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted February 22, 2012 (edited) 4167 said: 16x7 is better fit to E28 and tyre must use 215 50 or 55 R16 not 225. and I dont know 16x 8 will fit.I fit 16x8 to my e39 and it become outer,I think will touch the inner guard if for E28. rings try Jono @ magswheels direct.I have been bought a set from JONO i have the e38 type , so has a mate of mine . you dont need hub rings with them . 16" by 8" ET23 225/50-16" tyre , just make the tyre doesn't have a big rim protector lip . plenty of clearance at the edge of the guards etc see pic below i now run 235/45-17" on 17" by 8" with et20 m5 throwing star wheels with no problems ,and the car is lower than in the pic with the 16" wheels http://images.trademe.co.nz/photoserver/58...622058_full.jpg Edited February 22, 2012 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
kiwi6539 3 Report post Posted March 12, 2012 I have some style 5s for sale. http://www.trademe.co.nz/Browse/Listing.aspx?id=455988524 or have for sale add on bimmersport forum.. Could be what your looking. Pm me Quote Share this post Link to post Share on other sites
