Jamex316
E39 coolant
My e39 530i is needing a top up of coolant each week. Is that normal?
no thats not normal for any car.
cooling system is full of recycled plastic. Generally speaking needs an overhaul around 100-130k mark depending on how old it is. You may get away with replacing one failed component at a time but if you have the money its good to replace everything at once.
As above....get it checked pronto.
DO NOT let it overheat-these engines dont react well to being overheated
How much coolant are you talking about? and have you found any visiable signs of a leak, wet carpet, green crusty stuff on anything. The expansion tanks can crack on the e39's also a faulty cap to name a couple of things.
But as Stated get it looked at pronto nothing BMW likes getting hot with out it putting a hole in your pocket.
Best of luck.
