hybrid 1045 Report post Posted March 6, 2012 2JBBF - Junction Box - Passenger 6BMOT - Engine electronics MS 80 6 Cylinder N51/N52K ABG - Airbag Module ABS*- Anti-Lock Brakes ACC*- Active Cruise Control ACC2*- Active Cruise Control 2 ACSM - Advanced Crash and Safety Management AEWS - Immobilizer AHL*- Adaptive Directional Headlights AHM - Trailer module AIC - Automatic Interval Control AKMB - Instrument Cluster AL - Active Steering ALBBF*- Active Backrest Width, Front Passenger ALBFA*- Active Backrest Width, Driver ALSZ - Light Switch Center AMP - Amplifier AMPH - HiFi Amplifier AMPT - Top HiFi Amplifier/System ANT*- Antenna/Antenna Tuner ARS*- Dynamic Drive ASC*- Active Stability Control ASK*- Audio System Controller BABG - Airbag Electronics BIT - Telematic Control Unit BFS - Passenger Seat Module BM - OnBoard Monitor BTM - Passenger Mirror Module BZM - Control Center, Center console CA - Comfort Access CAS - Car Access System CCC - Car Communication Computer CCC-A - Applications CCC-ANT - Aerial Tuner CCC-ASK - Audio System Controller CCC-GW - Gateway CD - Control Display CDC - CD Changer CEM - Clean Energy Module CIC - Car Infotainment Computer CID - Central Information Display CON - (front) I-drive controller CTM - Convertible Top Module CVM - Vert Module (Convertible Top Module) DAB - Digital tuner DDE - Digital Diesel Electronics DME - Digital Motor Electronics DSC - Dynamic Stability Control MK60E5 DSC+ DSP - Digital Sound Processor DVD - DVD Changer DWA - Anti Theft alarm system DWS - Deflation Warning System (= RDC low cost?) ECALL - Combox Emergency Caller EDC - Electronic damper control EDC SHL - Electronic damper control, rear left satellite EDC SHR - Electronic damper control, rear right satellite EDC SVL - Electronic damper control, front left satellite EDC SVR - Electronic damper control, front right satellite EGS - Electronic Transmission Control Unit EHC - Electronic ride-height control EKP - Electric fuel pump 3 Generation EKPS - Electronic fuel pump control EMA LI - Automatic reel, left EMA RE - Automatic reel, right EMF - Electromechanical parking brake EML - Electronic engine power control EPS - Electronic power steering EWS - Vehicle immobilizer FAS - Driver's seat module FBI - Flexible bus interface FBZM - Rear compartment control center, center console FCON - Rear compartment controller FD - Rear compartment display FD2 - Rear compartment display 2 FID - Read compartment information display FKA - Rear compartment heating/air conditioning system FLA - High beam assistant FRM - Footwell module FTM - Driver rearview mirror module FZD - Function unit roof FZD - Roof function centre GM5 - ZKE - Central Body Electronics GR- Cruise control GT - Navigation (older models I presume) GWS - Gear selection switch HKA - Rear automatic air conditioning HKL - Rear lid lift HSR - Rear axle slip angle control HUD - heads up display unit ICM - Integrated Chassis Management IHK - Climate Control/AC IHKA - Integrated automatic heating/air conditioning system IHKR - Integrated heating / air conditioning IKE - Instrument cluster IKI - Instrument cluster INSTR - Instrument cluster JBE - Junction box electronics KAFAS - Camera-based driver support systems KMB - body module KGM - body gateway module KHI - Headphones interface KOM - Instrument cluster KOMBI - Instrument cluster LCM - Light switching center LEW - Steering angle sensor LM - Lights module 2 LMA - light module LRA - Automatic headlight vertical aim control LRR - Longe range radar LSZ - Lights switching center LSMC - Left Stepper Motor Control (Adaptive Headlight Module Left) LWS - Light Switch M-ASK-BO - User interface M-ASK-GW - Gateway M-ASK-NAV - Navigation system MEDIA - Combox Media / Telephone MFL - Multifunction steering wheel MID - Multiinformation display MIR- Multiinformation radio MOST - System analysis MPM - Micro power module MRS - Multiple Restraint System NAV - Navigation computer NFRM - Driver's side footwell module NVE - Night vision electronics NVK - Night vision camera PDC - park distance control PGS - Passive Go System RAD - Radio RAD2-BO - User interface RAD2-GW - Gateway RDC - Tire pressure Control Low Cost BN2000 RDC - Tyre pressure control RDW - Tyre pressure control RFK - Reversing camera RLS - Rain/Light Sensor RLSS - Solar rain / light sensor RSE - High Rear-seat entertainment Professional RSE - Mid Rear-seat entertainment RSMC - Right Stepper Motor Control (Adaptive Headlight Module Right) SASL - Satellite A-Pillar left SASR - Satellite A-Pillar right SBSL - Satellite B-Pillar left SBSR - Satellite B-Pillar right SDARS - Satellite tuner SEC1 - Supplementary control unit 1 SEC2 - Supplementary control unit 2 SES - Language input system SFZ - Satellite vehicle center SG-FD - Control unit, rear compartment display SG-FD-GW - Control unti, rear compartment display, gateway SGM-SIM - Safety and gateway module SGM-ZGM - Safety and gateway module SHD - Sliding / tilting sunroof SHZH - Independent / aux. heater SIM - Multiple restraint system SINE - Siren with tilt sensor SLM - Seat memory driver SMBF - Seat module passenger SMBFH - Seat module passenger side, rear SM - Seat Memory SM BA - Passenger's seat module SM BFH - Seat module, passenger side, rear SM FA - Driver's seat module SM FAH - Seat module, driver's side, rear SMF - Seat memory driver SMG - Sequential Manual Gearbox SSH - Satellite, seat, rear SPMBT - Mirror memory passenger SPMFT - Mirror memory driver SSBF - Satellite, seat, passenger SSFA - Satellite, seat, driver STH - Park heating STVL - Satellite, door, front left STVR - Satellite, door, front right SVS - Language processing system SVT- Servotronic SZL - Switch center steering column SZM - Switching center, center console SWW - Lane change warning SZL - steering column control unit TCU - telematic control unit/ bluetooth telephone TEL - Telematic control unit TGBT - Passive Go System TGFT - Passive Go System TMBF - Door module. front passenger TMFA - Door module, driver TPMS - Tire pressure monitoring system TLC - Lane departure warning TRSVC - Control unit for the rear view camera and SideView UEB - Rollover Sensor ULF - Universal charging and hands-free facility ULF-SBX - Universal charger and hands-free facility, interface box (Bluetooth telephony) ULF-SBX-H - Universal charger and hands-free facility, high-level interface box (Bluetooth telephony, voice input and USB/audio interface) VDM - Vertical Dynamics Management VID - Video module VM - Video module VSW - Video switch VTC - Valvetronic VTG - Transfer Case WIM - Wiper module ZBE - Central control unit ZGM - Central gateway module ZHZ - Additional heating (diesel) ZKE/GM - Central body electronics/GM base module Quote Share this post Link to post Share on other sites
