simonvv 2 Report post Posted March 8, 2012 Looking for some upgraded brakes for my 635CSi that will bolt straight on with no fabrication needed. Not sure of series but see pic below... "This kit fits the E28 5 series and E24 6 series form 1982 to 1988. It does both front and rear. Front is BMW 750 components and rear is BMW 540. The difference in stopping power is huge. This is a "Bolt On" with no fabrication or special tools required. Kit includes rebuilt calipers with pads, rotors and stainless steel hoses. Since the kit uses BMW components future maintenance or replacement is not an issue." If anyone can enlighten me on whats in the photo and where I can get some that would be great! Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted March 8, 2012 yes i run the same sort of set up in my e28 m535i that i use on the track etc. just use the front brakes from a e32 735i 740i 750i or e34 540i etc rear brakes from a e34 540i . you can use the rear calipers from a e32 740i or 750i but you will need the discs from a 540i. the other types you can use are from e31 840ci 850i 850csi or e28 m5 e24 m635vsi e34 m5 etc but the advantage of using the e34 540i type is the discs and pads are pretty cheap and easy to get what year is your e24 635csi?? may be able to help. also i have some adaptor plates so you can use front brakes from a e38 728i 740i 750i etc Quote Share this post Link to post Share on other sites
topcat 11 Report post Posted March 8, 2012 ive got a set of 540i front and rear disk and calipers,that will bolt straight up and work very well. front rotors like new,rear have not been check yet. $250 for the lot. add some steel brake hoses,and you be set with a very responsive brake setup Quote Share this post Link to post Share on other sites
simonvv 2 Report post Posted March 9, 2012 Boom! Much difference between the 5 series and the 7 series set ups?? Or would it be best to source some big 7's The car is a '83... ive got a set of 540i front and rear disk and calipers,that will bolt straight up and work very well. front rotors like new,rear have not been check yet. $250 for the lot. add some steel brake hoses,and you be set with a very responsive brake setup Quote Share this post Link to post Share on other sites
simonvv 2 Report post Posted March 9, 2012 If you have a set up available like you just eluded me to Id be keen to see what you will offer. I cant wait for better brakes! yes i run the same sort of set up in my e28 m535i that i use on the track etc. just use the front brakes from a e32 735i 740i 750i or e34 540i etc rear brakes from a e34 540i . you can use the rear calipers from a e32 740i or 750i but you will need the discs from a 540i. the other types you can use are from e31 840ci 850i 850csi or e28 m5 e24 m635vsi e34 m5 etc but the advantage of using the e34 540i type is the discs and pads are pretty cheap and easy to get what year is your e24 635csi?? may be able to help. also i have some adaptor plates so you can use front brakes from a e38 728i 740i 750i etc Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted March 9, 2012 Boom! Much difference between the 5 series and the 7 series set ups?? Or would it be best to source some big 7's 540i fronts are the same as 735i 740i 750i etc. rears are also teh same but the 735i and maybe the 750i are solid so they are no good but the 740i rear haver the same calipers as the 540i but the e32 discs wont work , you need e34 540i or m5 rear discs etc. The car is a '83... If you have a set up available like you just eluded me to Id be keen to see what you will offer. I cant wait for better brakes! call me if you like 021 433600 Quote Share this post Link to post Share on other sites
