740i 0 Report post Posted April 24, 2012 have 97 740 want to take out 4-3 tv moniter and fit 16.9 is this straight swap need advice thanks Quote Share this post Link to post Share on other sites
KwS 2448 Report post Posted April 24, 2012 AFAIK the fittings are the same as E39? If it is, just did this on my E39 and it was straight plug and play. You may need to upgrade the Video Module to get the image on the screen to be 16:9 not 4:3 though. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted April 24, 2012 AFAIK the fittings are the same as E39? If it is, just did this on my E39 and it was straight plug and play. You may need to upgrade the Video Module to get the image on the screen to be 16:9 not 4:3 though. Yup, E38/39 the same & yes to the VM as well. The X5 monitor, although looking the same, is not as it has a different pixel layout to allow for the different viewing angle. One thing though, a while back I supplied a 16:9 monitor upgrade to a person for an E38 about the same vintage, apparently the monitor body fouled slightly with the heater ducting or enclosure behind & not allowing it to fully seat. I think the problem was overridden ok. I am not aware of the A/C variations between early & late E38's myself Quote Share this post Link to post Share on other sites
