deeveus 81 Report post Posted May 9, 2012 BMW Professional - the radio works fine but sometimes it stops audio, the screen doesn't turn off, the sound just stops, normally when starting, it will be fine for a few seconds then turn off. It's on a E46 320d NZ New. Cheers Quote Share this post Link to post Share on other sites
euroriffic 603 Report post Posted May 9, 2012 Be a dry solder joint in the amp. Read about this in the total BMW mag. More common on the e39 but I'd say they use the same gear Quote Share this post Link to post Share on other sites
