bmwsparkle 3 Report post Posted July 15, 2005 (edited) thread mainly aimed at anyone that knows heaps about M30s (ie brent) and toyotas (glenn), anyone put a W55 toyota gbox behind a m30 before? How do they price out glenn? and anyone have any idea on what you would need to modify, for example would I use part of a motronic bellhousing to bolt it up, or a spacer of some sort sparkle Edited July 15, 2005 by bmwsparkle Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted July 15, 2005 thread mainly aimed at anyone that knows heaps about M30s (ie brent) and toyotas (glenn), anyone put a W55 toyota gbox behind a m30 before? How do they price out glenn? and anyone have any idea on what you would need to modify, for example would I use part of a motronic bellhousing to bolt it up, or a spacer of some sort sparkle how does motronic get its signals on the M30? From the gearbox or from a rpm sensor on a spark wire and a bigwheel/magnet combo on the front of the motor? Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted July 16, 2005 sparkle . i have a freind with a 525i manual . you could buy the whole car or just the kit from him. i think he wants $600 for the kit . you would need to do the little mod to the flywheel .(i can give instructions ) and tap and drill the sensor pick up thingy's into the bell housing. dont bother with toyota gearbox , easier to find bmw one . andrew . the e28 535i has 2 pick ups on the bellhousing . the e34 535i has a spark plug sensor and crank sensor instaed (better system ) sparkle. you could convert your motronic engine wiring loom to a e34/e32 one with the ecu (which are better than e28 one ,more advanced newer designed system) then you wouldn't need to worry about the flywheel sensors . ps. let me know if you want the 5spd conversion kit . Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted July 16, 2005 looms are easy swap loom over, then no need to use the gearbox sensors. auto is gay..go 5 spd and the more advanced thing is all relative..its still 10+ years old Quote Share this post Link to post Share on other sites
