speedyg 19 Report post Posted June 27, 2012 Hi, I have just replaced the water pump and viscous clutch in my car, all is running good again. On startup the viscous fan is really noisy ie. going flat out and shifting some serious amounts of air. After about a minute it quietens down and sounds normal, but will get noisy when accelerating off from a standstill when cold. My question is, does this sound normal and is it just the new viscous coupling? It is a after market one from Millands, brand :Hans Pries Topran (sounds German ) I am tempted to put the old one back in which was working fine. Quote Share this post Link to post Share on other sites
Jo Blogs 11 Report post Posted June 27, 2012 Hi, I have just replaced the water pump and viscous clutch in my car, all is running good again. On startup the viscous fan is really noisy ie. going flat out and shifting some serious amounts of air. After about a minute it quietens down and sounds normal, but will get noisy when accelerating off from a standstill when cold. My question is, does this sound normal and is it just the new viscous coupling? It is a after market one from Millands, brand :Hans Pries Topran (sounds German ) I am tempted to put the old one back in which was working fine. That Is a sign of a healthy viscous!!! Quote Share this post Link to post Share on other sites
yng_750 247 Report post Posted June 29, 2012 yea viscous should do that you will hear the same roar from most vehicles with a viscous fan Quote Share this post Link to post Share on other sites
Neal 576 Report post Posted June 29, 2012 Should sound similar to a Holden 202 when it's good Quote Share this post Link to post Share on other sites
speedyg 19 Report post Posted June 30, 2012 Ok, all good then. I was reading on a few other websites that the OEM viscous is much quieter than aftermarket. I guess I will just get used to it. Quote Share this post Link to post Share on other sites
