friends11 0 Report post Posted June 29, 2012 Hello there, Can any one help me ? My car E39 530i, Japan spec I can't find my radio module in the trunk. I'm going to replace the wide screen with aftermarket but I can't locate radio module in the back so that I can plug the new item. I removed the amplifire but nothing behind it. I'll show photos for my trunk module maybe you can help me. http://store2.up-00.com/Nov11/tax23594.jpg http://www.gulfup.com/show/Xktwaqu5n5ds http://store2.up-00.com/Nov11/lFF23744.jpg http://store2.up-00.com/Nov11/tXT23744.jpg http://store2.up-00.com/June12/ehb97590.jpg http://store2.up-00.com/June12/TXJ97590.jpg http://store2.up-00.com/June12/sNJ97590.jpg http://store2.up-00.com/June12/yL397590.jpg Plz Help Quote Share this post Link to post Share on other sites
matt45 1 Report post Posted June 29, 2012 no offense but those photos aren't very helpful u need to step back and take 1 of everything where it should be. from memory i believe its the silver box to the left of the amp ... you should be able to tell what by what box has coax antenna plugs going into it. there should be 2 of these 1 for radio 1 for tv, looking at the label with part number should help you decide which ... or just unplug antenna from one and see if you loose radio or tv. Quote Share this post Link to post Share on other sites
kiwiland 3 Report post Posted June 30, 2012 I believe its mounted behind the rear seat. You need to remove the boot liner to access it. Also the tv module if fitted will be in the same area Quote Share this post Link to post Share on other sites
matt45 1 Report post Posted June 30, 2012 I believe its mounted behind the rear seat. You need to remove the boot liner to access it. Also the tv module if fitted will be in the same area opps .... yes on a japa he is correct. Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted June 30, 2012 behind the rear seat Quote Share this post Link to post Share on other sites
friends11 0 Report post Posted June 30, 2012 behind the rear seat Oh my god guys U R the best, U don't have any idea how much I lost searching for this. U R right, I found it behind the rear seat. I want to buy you dinner guys for your help, bet I live in Saudi Arabia again thank U Quote Share this post Link to post Share on other sites
