nath 176 Report post Posted July 8, 2012 Hi Guys I have a ZF 4HP22 auto transmission which produces a load- dependent shudder changing from 2nd to third gear (takeoff speed from a standstill). I Think it is those gears and not 1st to 2nd. All other gears are fine, there is no slippage or flare anywhere or reverse. Any thoughts on this? The driveshaft etc is all covered by a heat sheild and under that are 2 large exhausts so I cannot at this stage see the flex disc coupling etc. Any useful info or experience? Cheers. nathan Quote Share this post Link to post Share on other sites
