frashn88 1 Report post Posted July 16, 2012 Cylinder head off M52b28 Brought engine as a 2.8 stroker kit for my engine. http://www.trademe.co.nz/Browse/Listing.aspx?id=494590081 A.I.W.I. condition as i havent had it checked. 027 559 8888 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 16, 2012 You will probably find that head is knackered going by the No2 picture which shows the piston and bore damage created by severe overheating. Checking this would cost more than the head is probably worth. It would need a hardness check, pressure test, crack test and also check that it is straight. Quote Share this post Link to post Share on other sites
