aw-krazy 45 Report post Posted July 22, 2012 Hi im looking for a set of front brake discs, non vented type for a e34 520i. Any suggestions where i can buy them cheap? Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2136 Report post Posted July 22, 2012 Hi im looking for a set of front brake discs, non vented type for a e34 520i. Any suggestions where i can buy them cheap? get e34 540i calipers (second hand), and 540i pads and disks. bolt on and a noticable improvement over the 520i bits. flush lines and use new fluid while you are at it. Quote Share this post Link to post Share on other sites
aw-krazy 45 Report post Posted July 22, 2012 get e34 540i calipers (second hand), and 540i pads and disks. bolt on and a noticable improvement over the 520i bits. flush lines and use new fluid while you are at it. Just my run about car :/ only looking to replace the stock discs with new ones. But that's be nice Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2136 Report post Posted July 22, 2012 (edited) in that case BNT is cheap, and if you know a NZBMWCC member they will have discount on top of that. EuroItalian is a Forum sponsor and they are also probably pretty good, I havent brought brakes stuff from Gav tho Edited July 22, 2012 by _Ethrty-Andy_ Quote Share this post Link to post Share on other sites
aw-krazy 45 Report post Posted July 22, 2012 in that case BNT is cheap, and if you know a NZBMWCC member they will have discount on top of that. EuroItalian is a Forum sponsor and they are also probably pretty good, I havent brought brakes stuff from Gav tho Cheers, will call them tomorow and get some quotes, will let you know how cheap i can get them Quote Share this post Link to post Share on other sites
