smiddy
Part throttle intake noise
Hi Guys, have a part throttle[just above idle] underload pulseing air vibrating Woommp-Woommp type of noise. Have had a bit of a feel around intake but looks ok. Car runs and idles fine. Wondering if anyone has struck this before, crankcase valve, idle valve???? Thanks.
Edited by wayney
Maybe a Video might help?
My E34 makes a pretty weird sucking noise when it's on the ICV.
Are you sure it's intake? Are you getting any vibration through the car?
No vibrations. Looking further and reseaching would indicate the PCV valve / oil seperator.
They are a common fail and produce a goose like groan at part throttle load or blipping throttle.
Removal of filler cap while engine is running produces sound. Also a weeping oil leak is evident under manifold, another tell tale sign.
