740i 0 Report post Posted August 9, 2012 Put 3.5 jack from iphone to 3.5 av in at back of console get av on screen. Says mute cant get mute off any ideas. Thanks Quote Share this post Link to post Share on other sites
jimbo01 0 Report post Posted August 9, 2012 Put 3.5 jack from iphone to 3.5 av in at back of console get av on screen. Says mute cant get mute off any ideas. ThanksWhat says mute, the E38 system? Isn't there a jack for the sound (mono) as well as AV? Quote Share this post Link to post Share on other sites
740i 0 Report post Posted August 10, 2012 What says mute, the E38 system? Isn't there a jack for the sound (mono) as well as AV? The sceen comes up with mute in green at bottom of screen But no sound, somebody wrote on another bmw site that it would,nt play iphone through the av outlet so put sony mp3 player same result. Thanks Quote Share this post Link to post Share on other sites
jimbo01 0 Report post Posted August 11, 2012 http://www.meeknet.co.uk/e38/AV/Index.htm Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted August 13, 2012 The sceen comes up with mute in green at bottom of screen But no sound, somebody wrote on another bmw site that it would,nt play iphone through the av outlet so put sony mp3 player same result. Thanks The AV-IN plays any AV source I had my iPod connected to it You must have the TV settings the same (ie: PAL for device and for AV in) and you must have the wiring correct The AV-in is a 3.5mm stereo socket, with: Body=Ground Ring=Video Tip=Audio Only mono audio, so connect Left and Right audio together for Mono. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted August 13, 2012 The AV-IN plays any AV source I had my iPod connected to it You must have the TV settings the same (ie: PAL for device and for AV in) and you must have the wiring correct The AV-in is a 3.5mm stereo socket, with: Body=Ground Ring=Video Tip=Audio Only mono audio, so connect Left and Right audio together for Mono. thats probably where the issue is, a standard 3.5mm plug has the tip for one channel and the ring for the other and the body ground, and a standard av cable has 2 rings like this pic. as opposed to: Quote Share this post Link to post Share on other sites
