E30Callum 1 Report post Posted August 12, 2012 Hey im new to bimmersport and E30s, I was thinking of getting some lenso klassics for my E30 and just wondered if by any chance anyone knows if this offset and width would fit on nicely without causing me any problems with rubbing and caliper clearance etc. it has been lowered too. Wheel:17 Width:8.5 Wheel Offset:15 Any help would be very helpfull and appreciated. Thanks Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted August 12, 2012 should be fine, may get some rub depending on what tyre you run on them though, thats quite a wide wheel for an E30 Quote Share this post Link to post Share on other sites
Guest Ari Gold Report post Posted August 12, 2012 PFL or FL? I ran 17x8.5 ET17 on the rear of FL arches and they rubbed under full compression, but that was with no guard roll. Fronts will definitely need massaging, no way you're gonna be able to run that up front without work. Caliper clearance depends on the profile of the rear of the wheel. Quote Share this post Link to post Share on other sites
