icedemon 0 Report post Posted August 17, 2012 hey guys, this might be quite a simple question, but I have a 1993 BMW 318is which im trying to remove current 4-spoke srs worn steering wheel on, to replace with a near new wheel from a 1996 320i. the problem im having is that I can feel behind the 4 spokes, and there are 'screw holes' but they look more like metal 'grommits' than any sort of screw. I'm unsure if I should just be prying the SRS unit out as i've tried and it feels like im going to snap something or bend the screw driver. heres a picture from behind, anyone know if im just meant to pry the airbag unit off? if so, does anyone know if the 1996 320i 4 spoke wheel (with 2 torx screws) will fit the 318is properly (the srs connector & the column)? http://iforce.co.nz/i/zpsdhh3n.pas.jpg Quote Share this post Link to post Share on other sites
icedemon 0 Report post Posted August 17, 2012 gah figured it out. theres actually 6 screws in total - there are 2 others closer to the signal & wiper sticks. it seems that the wheel is more like an E31 - and the connections dont match a later generation E36, so after all that effort - i cant actually fit the wheel that I do have (seems the setup is a lot different - not just simply splicing connections, because of the horn hub being conductive, vs the other wheel I have) Quote Share this post Link to post Share on other sites
Wom 0 Report post Posted August 17, 2012 my car came with a 4 spoke and I changed it for a sportier looking 3 spoke had to change over the switch bracket, take out the horn contact switch, and reconnect up the horn wire minus the contact switch these really helped a lot http://www.frankies-bmw.com/3series/diy/st...ering_wheel.php http://e31wiki.org/wiki/Steering_wheel_swa..._switch_bracket Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted August 17, 2012 (edited) have options for early airbag type 3 and 4 spoke etc., incl the type which has all the airbag electronics in the steering wheel itself brand new old stock like this one Edited August 17, 2012 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
