e30morgs 0 Report post Posted August 21, 2012 Battery has been going flat so tested the battery, alternator was all as normal so tested for parasitic drain; Caused by circuits; - 21. (7.5) Interior, glovebox and luggage compartment lights, torch, clock, radio memory, on-board computer - 24. (15) Hazard warning flasher - 28. (30) Cigarette lighter, motor-driven radio aerial, independent fuel-burning heater Motor driven arial stopped working prior to this problem also After some advice as to how to go about fixing this? Cheers, Morgan Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted August 21, 2012 how many amps is being drawn??? unplug each item one by one untill the amps drop down clock will use some power. glove box light swiches often fail or the mount is bent etc and the light stays on also check cig socket is clean inside Quote Share this post Link to post Share on other sites
e30morgs 0 Report post Posted August 21, 2012 how many amps is being drawn??? unplug each item one by one untill the amps drop down clock will use some power. glove box light swiches often fail or the mount is bent etc and the light stays on also check cig socket is clean inside Reading with all fuses in;0.14AReading with 21 out; 0.02 Reading with 24 out; 0.01 Reading with 28 out; 0.03 Cheers Quote Share this post Link to post Share on other sites
Etwenty1 45 Report post Posted August 21, 2012 Reading with all fuses in;0.14A Reading with 21 out; 0.02 Reading with 24 out; 0.01 Reading with 28 out; 0.03 Cheers Check your unloader relays - K5 or K7 iirc Quote Share this post Link to post Share on other sites
e30morgs 0 Report post Posted August 22, 2012 Check your unloader relays - K5 or K7 iircTried them, They're fine Quote Share this post Link to post Share on other sites
dkwl93 0 Report post Posted March 24, 2017 Sorry to revive a 5 year old thread but did you find out the cause of this? My 1990 E30 325i has EXACTLY the same fuses drawing current. They're drawing 1.9A with all of them in with the majority being drawn by #21 (~1.8A) Any update would be amazing. Thanks Quote Share this post Link to post Share on other sites
