tenga
Windows Fogging
Hey,
Just wondering if anyone knows why my car always seems to fog up when Im driving it. I have checked to see if there is anything wet but nothing is. After I defog it couple of minutes later it fogs up again. Any clue what it might be?
T
More details are probably needed. Does it fog up only when the heaters on, is it fogged up before you get in the car or only when your driving... etc
Rain leeks maybe - Have you lifted the carpets in check for moisture?
Recommend RainX, they do an antifog product for application to the insides of the windows
As above - check under carpets. Heater leak maybe - is it using water?
make sure you periocically have the a/c on fresh air,not reciculate ALL the time
