Laydeekrunk 0 Report post Posted September 3, 2012 Failed WOF because of the steering system. steering wheel has been squeeling (sounds like a spring being pulled apart like on a trampoline) when turning left and it won't self centre itself. It's not the power steering fluid, had that flushed out, topped up with fluids and pressure checked by a mechanic who replaced the lid because the liquid was seeping out. That has since stopped leaking. replaced the steering rack, only to find out the arms were bent? Left side of steering rack has excess play in it so I had to get a new joint or arm for the left side. (did not replace whole steering rack a second time round) can anyone tell me why this would happen? I have to get the mechanic to fit the arm and do a wheel alignment. Quote Share this post Link to post Share on other sites
Jono51 61 Report post Posted September 3, 2012 Failed WOF because of the steering system. steering wheel has been squeeling (sounds like a spring being pulled apart like on a trampoline) when turning left and it won't self centre itself. It's not the power steering fluid, had that flushed out, topped up with fluids and pressure checked by a mechanic who replaced the lid because the liquid was seeping out. That has since stopped leaking. replaced the steering rack, only to find out the arms were bent? Left side of steering rack has excess play in it so I had to get a new joint or arm for the left side. (did not replace whole steering rack a second time round) can anyone tell me why this would happen? I have to get the mechanic to fit the arm and do a wheel alignment. "(sounds like a spring being pulled apart like on a trampoline) when turning left and it won't self centre itself. " could be a seized tophat bearing issue, the strut spring will be twisting get it checked to confirm tho Quote Share this post Link to post Share on other sites
